Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-05-2007, 11:30 AM
bama_boy71 bama_boy71 is offline
1995 Bonneville stalls at idle speed
My girlfriends bonneville recently started eating fuel pumps, has been through 5 in the last 20,000 miles, 3 of them in the last 6,000 miles. It didn't run when I first met her about a year ago, I changed the fuel filter (as it was plugged tight), one coil pack, and replaced the vaccum hoses and gave it a tune up to get it going, ran great and got about 30 miles to the gallon. Shortly after, it ate a fuel pump. I bought a new tank and installed it with the new pump. Didn't help, wound up burning up another pump, more dirt. Figured out her ex was dumping dirty water in the tank and bought a locking gas cap to cure that nonsense. Fixed it again, this time with a used pump out of a friends car, ran better than ever before, then all of a sudden it developed an issue where now it stalls out randomly at idle, whether in gear or not. It only does it when not under acceleration, sometimes will start right and others will not, I noticed yesterday i do not hear the fuel pump running when it wont, replaced the relay and cleaned grounds, new filter, additive. Runs Great when it runs, any ideas?
Old 07-05-2007, 02:35 PM
Mickey#1 Mickey#1 is offline
Re: 1995 Bonneville stalls at idle speed
Did you clean the driver's side ground bus?
Old 07-05-2007, 02:38 PM
ChemMan ChemMan is offline
Consider flushing the tank well next time you drop the tank.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 07-05-2007, 02:51 PM
I cleaned the drivers side ground bus using a commercial electrical cleaner, no change, looks as if I'll be installing another fuel fuel pump, unless someone has a better idea to try first.
Old 07-05-2007, 06:13 PM
Did you pull the metal bar from the bus & was it the bus with all the black wires? If the metal bar has corrosion you'll need to clean it with sandpaper. You'll need to clean the female portion of the bus also.
Old 07-06-2007, 12:52 PM
azu azu is offline
Originally Posted by bama_boy71
it stalls out randomly at idle, sometimes will start right and others will not, I noticed yesterday i do not hear the fuel pump running when it wont, Runs Great when it runs, any ideas?
How are the power windows, locks and power seat? If they are acting up that would be the ground buss by the front doors and/or the other 5 grounds(Three under the hood and 2 in the cabin)
I had same problem with mine. Could be fuel regulator also.
I would eliminate the grounds first. If you still have problems it may be a problem with the crank sensor/circuit or cam sensor/circuit. Good luck!
The only dumb question is the one you didn't ask!
95 Pontiac Bonneville SE 194K
97 Ford Taurus SE 63K
00 Ford Ranger XLT 93K
06 Ford Taurus SEL 24K
Old 11-18-2008, 01:38 PM
firehawk_0071 firehawk_0071 is offline
Your problem is that your not putting in the Correct Fuel Pump. I had the same problem with my Silhouette. Theres the 3.1 carb fuel pump,the 3.8 fuel pump, the 3800 fuel pump and the latest one that covers some of the 3800 and some of the 3400 series. the 3.8 and the 3800 fuel pumps are not the same, if you put the wrong one it, it quickly burns out and starts blowing fuses.
Old 11-18-2008, 05:54 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Welcome to AF.
Thanks for contributing but please check the date and do not reply to old threads. This thread has been closed.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
