Old 07-05-2007, 10:57 AM
chives34 chives34 is offline
Exclamation Need Help!
Im really new to this car audio stuff and i need help with what amp to buy for Kicker Dual 12" Comp Subwoofers in Vents here are the specs
Amplified
No
RMS power handling (watts)
150
Frequency response (kHz)
27Hz - 500Hz
Peak power handling (watts)
300
Impedance per voice coil (ohms)
4
Peak power range (watts)
300-799
I was planing on buying a Pioneer GM-7300M is this the right choice? if not what would you suggest please post something!
Old 07-05-2007, 10:39 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Need Help!
you need an amp that candeliver appx 300 watts RMS into a 2 ohm load or 150 watts X2 channels into a 4 ohm load.
Old 07-06-2007, 11:40 AM
danthesk8er danthesk8er is offline
Re: Need Help!
Yes that amp is just fine for the subwoofers you are getting. Just be sure not to turn it too loud. The amp has a little more power than the subs can handle, which is ok. If you hear your subs clipping turn it down. I have a 1700 Watt 900RMS Kenwood amp for my infinity sub which only is suppose to handle 350RMS. It works just fine. Just be sure you don't turn it up too loud and it won't hurt anything. I'm assuming you will be wiring the subs in parallel so you will drop the ohms to 2. Just wire both positives to the positive and both negatives to the negative terminal and it will run quite smoothly. Good luck!
