Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 07-05-2007, 09:21 AM
jeffbull jeffbull is offline
2000 accent hard to start
Hi
I would be grateful if someone could give me some idea about what the problem is with my 2000 accent.
For the past few months I have had a reoccurring problem with it not starting (turns over will not fire). This is intermittent, as I can go two weeks with out of problem, and then suddenly just will not start. I have also noticed around this time that it is rough idling, and also appears that the engine fan remains on a lot longer than normal. It also does not run that great when I put my foot down. (this is also intermittent but around the time I have trouble starting it)
I also have a check engine light on reading code P1128, could this be the cause?
I understand this relates to a faulty MAF, but I have also been informed that it could also be a faulty TPS sensor, an idle speed actuator or a faulty valve in the evap canister.
Anybody have any ideas before a spend £60 on a new MAF. I am a single dad, and a bit short of cash (no need for violins).
Thanks for reading
Jeff
Old 07-07-2007, 02:44 PM
sidv6 sidv6 is offline
Re: 2000 accent hard to start
hi jeff, try disconnecting MAF if runs ok after that its the MAF that could be faulty. good luck
Old 07-07-2007, 03:35 PM
Hi Thank you for taking time to reply, I shall give that a go. Many thanks jeff
Old 07-31-2007, 02:07 AM
niceman niceman is offline
I should say it could be a MAF issue.Try to check it then you can replace it with new Hyundai parts MAF.goodluck my friend.
