Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-05-2007, 08:39 AM
burchard burchard is offline
differential gear worn out
Camry 95 automatic 4 cyl (415000km), the differential gear is stripped . Do I need to change the whole tranny or just the diff. gear?. I understand that the transmission and diffrential gear seat in complete separated compartments therefore, there is no chance that the diffrential gear debris could interfere with the transmission gear. Is this correct?. Any comment would help... Many thanks
Old 07-05-2007, 11:43 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Re: differential gear worn out
How do you know the differential gear is stripped?
Seems unlikely that those hardened, constant mesh gears would strip. Even if oil changes were neglected, would expect bearings to be affected first.
The differential in a '92 4 cyl. is separate though, so you're correct in saying any debris would be isolated.
