Old 07-04-2007, 10:44 PM
midwestmotorsportz midwestmotorsportz is offline
94 buick lesaber custom
im trying to figure out how to change the water pump it looks like you have to pull the motor mount but then again it doesnt what am i missing any help would be absoultly gratefull my email is [email protected]
Old 07-04-2007, 11:27 PM
ChemMan ChemMan is offline
Re: 94 buick lesaber custom
Yes, the motor mount needs to be removed to get the pump out.
opcorn:
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 07-05-2007, 12:19 AM
spinne1 spinne1 is offline
Yes, you need to remove as the motor mount as has been suggested. Also, you want the job to be as easy as possible, so remove as much as you need to to make it easy to access the area. Certainly the alternator needs to come out. I believe I also undid the bolts holding the power steering pump and moved it out of the way, but I can't remember. It will become more obvious as you see what blocks it. You don't have to remove the whole front cover (thank goodness), BUT if you are going to do this job, seriously*consider a timing chain and gears and cam magnet. Yes, the front cover must come off, but if it is needed, it would be a good time to do it.
Old 07-05-2007, 02:57 PM
Blue Bowtie's Avatar
Registered Offender
I just replaced the pump on a '95 (last 231 before the Series II) and the front (right end) engine mount needs to be removed, both from the engine and from the RH subframe rail. The power steering pump and alternator can remain in place. You won't even need to remove any hoses.
Be CERTAIN that you apply sealant to the bolt threads for the pump (the longer 5/16" bolts) before assembling, or you'll be right back there looking for a "mystery" coolant leak, possibly into the oil.
When removing the engine mount, you'll likely discover why anti-seize compound is your friend.
Old 07-05-2007, 04:19 PM
I completely agree, but removing the alternator makes it much easier to see what you are doing. And yes, anti-seize is your friend. Use it!!
Oh, and make sure to break loose the water pump pulley bolts BEFORE you remove the belt. Trust me.
