Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 07-04-2007, 02:28 PM
sirplod sirplod is offline
96 Riviera trac control/abs system
I am considering buying a 96 Riviera, however the traction control and ABS don't work. The owner told me that they both went out at about the same time. She was going to get it fixed but was told that it was going to cost $2500!!! Can that be right or is the problem likely to be a whole lot cheaper??? And is this a common fault with these Rivieras??
Old 07-06-2007, 03:48 PM
96riviera18 96riviera18 is offline
Re: 96 Riviera trac control/abs system
it is fairly common on riv's. 2500 is about right considering the parts and labor involed at the dealership. both ABS and Trac will go at the same time b/c they are both controled by the same sensors and motor.
most of the time all you need is a new hub with speed sensor in one of the front wheels. a shop with the proper diagnostic tools can tell you exactly which wheel speed sensor is faulty. however on some rare occasions the actual trac/abs motor burns out and those can be pricy to replace. it is called a EBTCM (electron brake traction control motor) and can be 500 for the motor alone.
good luck! hope you have the chance to own a riv soon!
Matt
(oh and once you get your riviera, please join rivperformance.com )
Old 07-09-2007, 07:53 PM
Matt
OK...Thanks for that. I got the car so now I'll take it in and have it looked at..
