Go Back   Automotive Forums Car Chat > Oldsmobile > Toronado Trofeo
Old 07-04-2007, 02:06 PM
mich123 mich123 is offline
Unhappy trofeo sauna
I have a 92 trofeo, and I'll start the car then everything on thse panel goes blank except the tach. The defrost turns on automaticly and blows hot air. What can be done about this.
Old 07-04-2007, 02:52 PM
maxwedge maxwedge is offline
A990 racer
Re: trofeo sauna
Welcome to AF. What panel, dash, heater control?
Old 07-04-2007, 07:40 PM
Re: trofeo sauna
it's the instrument cluster, which is the digital odometer and the information center
Old 07-05-2007, 05:27 AM
A990 racer
Re: trofeo sauna
It is more than likely failing.
Old 07-05-2007, 08:12 AM
Re: trofeo sauna
yes I agree. But why? Any suggestions? I would like to fix it myself if possible
Old 07-05-2007, 04:17 PM
A990 racer
Re: trofeo sauna
Can you overhaul a digital dash, take it out and apart , look for bad soldered connections, if you feel up to this, if not exchanges are available. Also check for proper grounds in the dash circuitry.
Old 07-29-2007, 12:05 AM
DigitizedWarmth DigitizedWarmth is offline
Re: trofeo sauna
You're right. It IS the instrument cluster, and more specifically, a corrupt capacitor. The good news: cost a few cents to replace. The bad news: it is quite technical.
Here's a link that will tell you everything you need to know to fix it.
http://webspace.netmatters.co.uk/cau...iv/ipc_fix.htm
Old 07-29-2007, 08:26 AM
Smile Re: trofeo sauna
Thanks for the advice. I'm going to tackle it A.S.A.P the extra's about static control will be helpful. I'll let you know the outcome.
Old 10-09-2007, 12:18 PM
Re: trofeo sauna
Hi there, the link you set up is not working can you help me to locate it? thx
Old 10-09-2007, 12:21 PM
Re: trofeo sauna
could some one help me to find the instructions on how to replace the corroded circute in the cluster panel. the link does not go throgh. thx
