Old 07-04-2007, 11:19 AM
alliek alliek is offline
acceleration problems
I have an 04 alero 4 cyl. When I attempt to accelerate it takes forever to pick up speed. Sounds like a gas guzzling truck. Sometimes the rpm will rev up but car is struggling to pick up speed. Ive had the transmission checked, no problem there. Any suggestions
Old 07-05-2007, 06:49 PM
mtterry mtterry is offline
Re: acceleration problems
could be an ignition coil problem. possible your cylinders aren't hitting right
Old 07-08-2007, 04:30 PM
Iflylow's Avatar
Iflylow Iflylow is offline
A misfire would trigger the check engine light.
Possibly a clogged catalytic converter. You might also check the fuel filter and fuel pump. If the filter hasn't been changed in a while, just change it. It's a $10 part at Walmart, and a 15 minute job in your driveway.
