Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 07-04-2007, 08:46 AM
thumper89 thumper89 is offline
Rear end rattle
please help!!!! there is a very loud rattle coming from the rear axel that sounds like two pipes clanging together when driving down the street. any ideas?
Old 07-04-2007, 10:09 AM
taillight taillight is offline
Re: Rear end rattle
Check your exhaust system. What year, make and model?
Old 09-19-2007, 07:03 PM
dkoug
Guest
Posts: n/a
Question Re: Rear end rattle
On my 83 Lebaron, the rer shock bolt at top of shock produced a good rattle, just had to tighten it up.
Who knows, good luck
Old 09-30-2007, 08:11 PM
unforgiven1 unforgiven1 is offline
Re: Rear end rattle
From your discription it sounds like the sway bar, a round tube that runs inside the rear axle beam between the wheels. If you get under the car you can touch it from the bottom side of the beam. Push on it with your fingers and see if it moves. They break loose from the beam and ideally need to be rewelded. I always pull the brakes and weld them near where the original weld is located. Any compotent shop with a welder should be able to fix it.
