Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 07-04-2007, 01:47 AM
johnbarrett69 johnbarrett69 is offline
bigger motor
i have a 89 beretta gt and i wanna put a 350 from a camaro and wanted to know if the rear end and the unibody would built right up from a camaro or wut. i wanna figure it if its worth all the work.. iam pretty sure it would need some fab work to the firewall. and tunneling out for the driveline just wondering wut u guys thoughs were if it its truely worth it..
i had block work done to the old 2.8 and a oil pump and camshaft and some other lil stuff. it worked for a lil bit and then just started to act up so i just took a 3.1 from a lumina that my brother had. and thats wuts in it now..
Old 07-04-2007, 10:00 AM
Blue Bowtie's Avatar
Registered Offender
Re: bigger motor
Which motor? There might be up to 50 motors in a passenger vehicle:
LF Seat Front Tilt Motor
LF Seat Rear Tilt Motor
LF Seat Horizontal Position Motor
LF Seatback Tilt Motor
LF Lumbar Motor
RF Seat Front Tilt Motor
RF Seat Rear Tilt Motor
RF Seat Horizontal Position Motor
RF Seatback Tilt Motor
RF Lumbar Motor
Trunk Pull Down Motor
Sun Roof Motor
LH Mirror Vertical Motor
LH Mirror Horizontal Motor
RH Mirror Vertical Motor
RH Mirror Horizontal Motor
Primary Temperature Control Damper Motor
Passenger Temperature Blend Damper Motor
Front HVAC Blower Motor
Rear Heater Blower Motor
Rear AC Blower Motor
Front Wiper Motor
Rear Wiper Motor
Front Washer Pump Motor
Rear Washer Pump Motor
Primary Cooling Fan Motor
Secondary Cooling Fan Motor
Starter Motor
Fuel Pump Motor
ABS Front Modulator Motor
ABS Rear Modulator Motor
LH Headlight Door Motor
RH Headlight Door Motor
Air Ride Compressor Motor
Pedal Positioning Motor
Transfer Case Encoder Motor
Air Injection Pump Motor
Side Door Motor
Lift Gate Motor
EGR Stepper Motor
IAC Stepper Motor
Tape Transport Motor
CD Drive Motor
Audio Cooling Fan Motor
Seat Belt Track Motor
LF Window Motor
RF Window Motor
LR Window Motor
RR Window Motor
Power Antenna Motor
If you are asking about changing the ENGINE, that would be a more serious undertaking. The unitized body structure of a Beretta/Corsica is not designed to take drive thrust at the rear wheels. I suspect the roof panel and quarter panel sails would buckle in a very short time from the thrust and body torque, even if you could devise a means to securely mount the live axle in the rear.
Short of building and/or significantly reinforcing and clearancing the body/chassis of a wrong-wheel-drive unibody, there will be no easy way. It's not a weekend engine swap.
Old 07-04-2007, 01:19 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: bigger motor
I was thinking about doing that in my beretta. In addition to what Blue Bowtie said, you would have to alter the brake booster location (and probably convert to hydroboost), move the P/S rack (either much lower or to in front of the engine [which would mean altering the struts]). The radiator would have to be moved to the rear of the vehicle. The gas tank would have to be removed and replaced with a fuel cell in the trunk to allow for the driveshaft. If you look at the car from the side, you'll see that the engine would be just about centered over the front wheels, which means the back will slide out very easily with almost no weight back there.
And if your trans is M/T, there's not enough room for all the pedals after you cut the firewall out to make room for the transmission
I gave up on the idea of doing it in a beretta, but I'm going to try it in a Lumina. There's much more room and the suspension/brakes are better suited for several hundred extra pounds.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-05-2007, 08:46 AM
Registered Offender
Re: bigger motor
I believe a Lumina (or Monte) would be a lot easier, but still require a lot of work and reinforcement. That's not to say that is can't be done with a Corsica, but it would be a real effort.
Old 07-05-2007, 10:53 PM
Re: bigger motor
b.c. i have to a drag strips that 454s in beretta and it did 8 sec run. it freaking crazy.
or i was thinking about 3.8L supercharged i heard it builts right up. and getten block work done it and all that good shit...
blue bowtie y did u have to suck a ass...?btw berettas dont have rear window motors b.c. they dont go down.
Old 07-27-2007, 09:24 PM
Registered Offender
Re: bigger motor
I'm not sure how to respond to that...
The FWD V-6 or V-8 swap (Aurora/Northstar) would likely be a lot easier. 8 seconds is cool and all, but it doesn't take a Beretta. A lot of Novas are doing 7-second runs routinely, no boost, no blower, no Viagra gas. It's called "pro stock" class, and 500-ish Mk IVs are the norm. There's a guy in the 'burbs running a turbo Buick in a Cadillac CTS doing low 11s on pump gas and street legal tires, and only 15 pounds of boost. There is a YouTube video of it at GLD a few weeks ago:
http://youtube.com/watch?v=1_iR5vtnMBU
That would be cool in a Beretta, and probably closer to the 8-second 454s without all the hassle. That setup installed in the lighter car and with the boost up to a more normal 18 pounds should make it interesting.
