Old 07-04-2007, 12:53 AM
wildman_4x4 wildman_4x4 is offline
Unhappy 4X4 switch not working
After putting my truck into 4 hi and climbing up a steep hill I could not get it to go back into 2 hi. I notice that none of the lights are lit on my controll panel. I can hear it shift inbetween 4hi and 4 low in N any help?runaround
Old 07-04-2007, 06:20 AM
muddog321 muddog321 is offline
AF -Advisor
Re: 4X4 switch not working
Need the year and 3 or 4 buttons on dash switch as cases and vac switches diff type/location. Post back.
Old 07-04-2007, 12:13 PM
Post Re: 4X4 switch not working
My blazer is a 2001 with the 3 button switch there is no auto mode on it
Old 07-04-2007, 01:40 PM
Thumbs up Re: 4X4 switch not working
Wooo Hooo it's fixed I pulled the 3 button switch off the dash by gently prying it off with a plastic knife and found the harness almost disconnected. I reconnected it and pulled the 2 ECM mini fuses for 10 mins and presto it worked.
Old 07-04-2007, 02:37 PM
Sparky1349 Sparky1349 is offline
Wildman,
Good work, the old Do It Yourself spirit....F-ck with it until you figure it out. Great job and thanks for posting back the fix!
Sparky.
Old 07-04-2007, 05:26 PM
seeknstrike seeknstrike is offline
2 ECM mini fuses????
Where are those at?
My switch is not working either. i did the same as you, but everything is connected.
Where are the 2 ECM mini fuses located at? so I can try to reset them. Thanks
Old 07-05-2007, 07:33 AM
in the under the hood fuse box on the drivers side both fuses are near the center of the box. If you need the diagram for a 2001 I can take a pic of mine and post it.
