Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-03-2007, 09:17 PM
sleeper87si sleeper87si is offline
obd 1 map sensor on obd 0?
can an obd 0 computer accuratly read an obd1 map sensor, are there any differences between them
Old 07-03-2007, 11:34 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: obd 1 map sensor on obd 0?
Yeah. OBD-0 are single wire. OBD-I are heated 4-wire. Won't work. OBD-0's are the cheaper ones so why are you trying to use an OBD-I?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 07-05-2007, 01:59 PM
o yeah i no about the OXYGEN SENSOR. but im asking if the obd1 MAP SENSOR can be read by an obd0 computer. i have the obd0 map sensor in my 87 crx body, and its 3 wire. i have a obd1 plug for a obd1 map it and it is also 3 wire, will the right combonation of wires connect the map sensor accuratly an let the ecu read it. i put a b16 in my crx an it came with the obd1 map sensor on the top of the throttle body and its new so i wana use it.
Old 07-05-2007, 02:06 PM
NA is Best!
Haha, my mistake. I completely misread that. Anyway, I think the ranges are the same but the actual sensor its self may be different. Not 100% on that one though. I say if you've got it all already, just try it. MAP is a major sensor so you'll know quick whether it work or not.
