Old 07-03-2007, 03:46 PM
jonathanc's Avatar
jonathanc jonathanc is offline
Tires and Odometer
So i have 305/70/R17 tires on my 2004 silverado crew cab. How much is this affecting my odometer and speedometer?
Old 07-03-2007, 04:28 PM
cboyfan2020 cboyfan2020 is offline
Re: Tires and Odometer
probably a lot. in order to have the speedo work properly you have too "plus size the tires".Say your truck came stock with 265/70/16...then you want to change to 17" rims...tires would need to be 275/65/17 to acheice the same overall diameter.. Can affect speedo, abs, and handling....Not sure but some power chips will aloow you to reconfigure the ecm to accept the new size but not sure.
tech w/ 4 yrs exp.
ASE cert in A4, A5, A6, A8
Old 07-03-2007, 04:42 PM
silveradoman0574 silveradoman0574 is offline
What is the size of your stock tires?
White 02 Silverado Ext Cab
23" MOB Torrio Black and Chrome wrapped in Falken 285/35 R23 Tires
Flowmaster 40 series with turndowns
Alpine IVA-D310 7" Flipout touchscreen
Clear Headlights and bumper lights
Eurodesigns 8500K Hyperwhite High and low beams
All hyperwhite running and turning lamps
Old 07-03-2007, 05:13 PM
jonathanc's Avatar
I know the speedometer is off by 6mph but how is this messin up my odometer? Is it goin up quicker than it should or less? Stock tires were 265/70/R17.
Old 07-03-2007, 05:39 PM
Your speedo is 7% to slow which means when your speedometer reads 60 your actually going 64.2 mph. Now as far as the odometer goes the traveled distance will be greater than the measured distance but i'm not sure how much...
Old 07-03-2007, 06:38 PM
777stickman 777stickman is offline
If your speedo is showing 6 mph less than actual speed then your odometer will reflect less miles than actual.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 07-04-2007, 12:04 AM
jonathanc's Avatar
So lets say its 64 miles from pointA to PointB according to the raod signs. Then my odometer is gonna show that it was less than that say somethin like 62 miles.
Old 07-04-2007, 10:09 AM
OK let's try this. You said your speedo is off by 6 mph. With bigger tires it's going to read slower than actual speed. When it reads 60 mph you're actually going 66 mph. Say you drive at 60 mph for 1 hour you actually travel 66 miles but your odometer will only register 60 miles. Bottom line is that your odometer is going to register less miles now with the bigger tires.
57 Chevy 210
Old 07-04-2007, 06:05 PM
rjeffery rjeffery is offline
Dealer can reprogram for it. Also, handheld & professional tuners
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
