Go Back   Automotive Forums Car Chat > Oldsmobile > Oldsmobile Classics
Old 07-03-2007, 11:21 AM
Oldsmobile 57 Oldsmobile 57 is offline
Power Steering Pump Fluid Venting:
I have a classic 1957 Oldsmobile and while driving at highway speeds 65 to 70 mph the power steering fluid vents out large amounts of fluid through the the power steering pump vent bolt which is used to hold on the reserviour cover.
Any ideas why?
Old 07-03-2007, 12:09 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Power Steering Pump Fluid Venting:
Welcome to AF.
Your post has been moved to the Olds Classics forum.
Timeslip 08/12/06
AF Community Guidelines
Old 07-03-2007, 04:01 PM
maxwedge maxwedge is offline
A990 racer
Good chance it is overfilled, I assume you are using the proper fluid, which is not modern p/s fluid.
Old 07-03-2007, 05:07 PM
Thanks for the reply. The fluid level is not above the fill line. However I do not know it the fluid level should be checked with the engine hot while running or with the engine hot and not running. I am using Type A Transmission Fluid as was required for that year of vehicle.
Old 07-03-2007, 06:46 PM
A990 racer
Check it off, preferrably cold.
