Old 07-03-2007, 02:18 AM
midwestmotorsportz midwestmotorsportz is offline
94 buick harmonic balncer issues
i have a 94 buick lesabre and i have no spark when i crank an as well i have noticed that the bolt in the center of the balancer is spinnin an the belt assembly is not as well i turned the belt assembly by hand so that tells me the motors not lockd up thanx
Old 07-03-2007, 08:52 PM
Mickey#1 Mickey#1 is offline
Re: 94 buick harmonic balncer issues
Are you saying the bolt that holds the harmonic balancer is turning but the balancer is not?
Old 07-04-2007, 08:43 AM
Blue Bowtie's Avatar
Registered Offender
It sounds like the balancer is loose from the hub. That would explain the no-start, since the crank position sensor array gets its signal from the interuptor rings on the rear of the balancer (Fast-Start system).
Old 07-04-2007, 04:30 PM
thanx for all the input what had happened is the balancer had pretty much exploded on the in side i thought it was a massive job but found out it was a 10 min job thanx
Old 07-04-2007, 08:56 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Question Re: 94 buick harmonic balncer issues
This whole thread is confusing me! Could you explain how the balancer “exploded from the inside” and how you changed it in 10-min? I have changed quite a few harmonic balancers in my time, with the car on a lift and all the air power tools available, and I have never been able to do it in less than 45 min! Please help us understand your procedure.
