Old 11-02-2002, 04:18 PM
Clearcoats. Can you...
Can you spray a clearcoat over the decals have been put on? thanks.
Old 11-02-2002, 04:24 PM
cph81's Avatar
cph81 cph81 is offline
Yes.
That's what clearcoat for: protect decal.
Just Finished:
Old 11-02-2002, 06:37 PM
ex-r's Avatar
ex-r ex-r is offline
Yes you can. I use automotive clears without any effect. Just gotta make sure the decals are fully dried before applying the clear.
Old 11-02-2002, 09:01 PM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
Some decals don't like clearcoat, but I haven't had any problems before.
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 11-02-2002, 09:14 PM
935k3's Avatar
935k3 935k3 is offline
Be careful to dust the clear on in very light coats at first to gradually build it up then go for wetter coats.
Old 11-02-2002, 10:49 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
If I spray clearcoat over an enamel paint, won't the clear coat wrinkle?
Old 11-03-2002, 04:32 AM
BWheel BWheel is offline
Make sure that the paint you're spraying over has cured properly before clear-cote gets sprayed on. You'd be looking at the paint having cured for a week anyway before you prep the body with T-Cut or whatever anyway.
Once you have put the decals on, you'll also want to leave it for at least a day for them to dry correctly, preferably longer.
Question: Do you guys use decal setting solution much, or just lay them on straight?
Old 11-03-2002, 05:16 AM
Guido Guido is offline
I always use decal solution. It make the decal "stick" better. But after you've used solutions, make sure you give it enough time to dry, you should clean the solution solvants away with a damp cloth. Otherwise enamel clear will give you trouble with fish-eye effects etc.
Old 11-03-2002, 02:15 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Usually not. When layering two types of paint, always wait long enough for the underlying paint to dry, so that the remaining solvent won't affect the layer above. And when applying the 2nd paint, start with a few coats of mist, so that it won't dissolve the layer underneath it. As long as those principals are kept, you can almost always use any type of combination. Still, it's good to know that the strength of solvent
lacquer (unaffected by enamel or water)
enamel (unaffected by enamel)
water
As for clear coating decals, apply the spare decal, such as company logo on a scrap part, and test spray clear. That's the most certain way to avoid a mess-up.
I've used Tamiya spray, Dupli-Color and Gunze Mr. Color spray and Testor lacquer Gloss Coat and Gunze's waterless Top Coat spray cans on Tamiya, Hasegawa, Aoshima, Fujimi and Caltograf decals.
Hiroaki Fukuda
Old 11-14-2002, 10:35 PM
gcheok gcheok is offline
Can clear coat be applied to clear plastic? Like window frames and tail lights.
Old 11-14-2002, 10:39 PM
bvia's Avatar
bvia bvia is offline
Angry
Depends. Future (an acrylic floor "polish") is used by many to clearcoat clear plastics (windshields/tailights, etc), but some types of paints actually etch bare styrene plastic, which would craze the surface. Best to try ANY types of paint and combinations on scrap first. That way you're for sure and when folks like Hiro give you specifics, make sure to cut, paste and keep them handy!
hth,
Bill
:bandit:
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
Old 11-14-2002, 10:42 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Don't clearcoat clear plastic. It will fog it.
Old 11-15-2002, 01:17 AM
hmmm....so how do I protect the decals on clear plastic?
Old 11-15-2002, 11:29 AM
Jay! Jay! is offline
Horizontally Opposed
Future would probably serve you well in that case...
Hierarchy of Subaru:
(Click to see mine!)
Old 11-15-2002, 11:39 AM
giordano giordano is offline
another question: do i need to polish the paint make it even before spraying clear on it? or spray it with clear and then use polishing compound?
