Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 07-02-2007, 08:08 PM
lincolnls2002blk lincolnls2002blk is offline
Draining The Anti-Freeze
Does anyone have info on draining the anti freeze resevoir on a 2002 ls 3.9l?
Its unfortunate but now contaminated and i need to drain out the fluid. If this is a difficult process do you have any idea as to how much it may cost if i took it to a shop? Thanks for any of your knowledge.
Old 07-03-2007, 07:12 AM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
Re: Draining The Anti-Freeze
there is a drain cock in the lower passenger side of the rad.
it's a simple plastic plug that you loosen with a hex key - that's it.
there are some steps to refilling to make sure that you bleed all the air out.
http://www.lincolnvscadillac.com/tec...ystemDraining/
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
