Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 07-02-2007, 08:01 PM
barkz barkz is offline
Turbo
ok, might not be worth it but i figured i would ask. I can get ahold of a turbo off of a volvo, and i was just wondering if it would be possible or even worth trying to put in my 01 SOHC neon. i know ill need the manifold and everything else to go with it but i was just wondering if this is a way to put a cheap turbo setup in the car. thanks
Old 07-03-2007, 08:52 PM
denisond3 denisond3 is offline
Re: Turbo
Wouldnt you need to also change the pistons, to have a lower compression ratio?
Old 07-03-2007, 10:59 PM
Re: Turbo
no a stock neon motor can push 8psi safely, anything after that you need to start rebuilding.
