Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-02-2007, 07:17 PM
Ken_OY Ken_OY is offline
How to install a fog light?
I plan to install two fog light on my 95' camry, but where can I get the 12v power source?
1, could i just connect them to the side lamps or the head lamps?
2, is there a hole of the firewall that i could use for wiring?
Thanks!
opcorn:
Old 07-07-2007, 11:22 PM
nmikmik nmikmik is offline
Re: How to install a fog light?
I would check your wiring harness before attempting to go through the firewall. You should have the wires (and probably the place for the relay) on your vehicle already. Just pull wiring diagram for your model and check. IF it doesn't you will need to use the relay anyway cause "siphoning" on any other circuit will be a bad idea.
