Old 07-02-2007, 07:04 PM
paqman's Avatar
paqman paqman is offline
Installing A/C in Escort that don't have it?
Hey everyone, quick question for you. I've got a '97 Escort with a salvage title. I love this little puppy though. The guy I bought it from was a good friend at the time, and his dad was the one that rebuilt it, which was the reason I bought it. I've been driving it now for about 4 years, and not one problem. Love it. The engine only had about 20K miles on it when I bought it.
But here's the problem. I think when he rebuilt the car, he either didn't bother putting the A/C back in, or it never had A/C in the first place. I'm assuming it originally had A/C, but maybe you all could tell me if many Escorts came without it, or if it was standard.
So I would like to think about picking up some spare parts from the local salvage yard, and putting it in on my own if possible. I'm only a saturday mechanic, brakes, oil, simple stuff like that, but I'm very adventurous on this car, and willing to try just about anything if I've got the tools.
So I guess my question is how hard would it be to peice together an A/C system for this car and install it? I don't assume there's any guide out there that could help me is there?
Sorry that was so long, but I've been wondering this for a long time, and with the temperature in the triple digits where I live, I REALLY WANT AC!runaround
Current Vehicles:
2008 Nissan Altima ~ 115k miles
2010 Nissan Maxima ~ 74k miles
2007 Toyota Sienna LE ~ 145K miles
Goners
1997 Ford Escort ~145k miles (SOLD)
2013 Kawasaki Ninja 300 ~13k (SOLD)
1983 Honda Magna V45 ~13k (SOLD)
2004 Mazdaspeed Miata ~90k (SOLD)
2001 Ford Mustang GT ~86K (SOLD)
2007 Suzuki Boulevard M50 ~12k (SOLD)
2001 Nissan Maxima - (TOTALLED)
2001 Oldsmobile Intrigue (SOLD)
1991 Nissan Maxima (TOTALLED)
1989 Pontiac Grand Am (SOLD)
Old 07-03-2007, 07:00 AM
denisond3 denisond3 is offline
Re: Installing A/C in Escort that don't have it?
I have seen some Escorts in salvage yards in Pennsylvania that didnt have a.c. on them. Temperatures of 100° in PA are rare.
Adding an a.c. is going to be a BIG job UNLESS it had one that wasnt re-installed; in fact if it never had one, it might be an easier task to get an Escort that has an air conditioner, and use your current one as a source of spare parts. If it did have one once, I expect it would be feasible to add the missing pieces.
Here are some of the things you would have to do:
* First spend time in Salvage yards scoping out whether it is feasible at all, whether yours had one once, and if so how much of the works are still in the car. I know on a Dodge Omni, if the car came without an a.c. the firewall is different, and wont have any place where you can make the opening for the a.c. piping. I dont know about Escorts.
Then, if it seems feasible, here are some of the steps:
* Add the evaporator under the dashboard. If I had to do this, I would get the entire heater/evaporator assembly from a salvage yard, with all control cables, and the control head (where you set the temperature and air flow). Then you would have to remove the dashboard, to have access for replacing the 'heater-only' unit in your Escort.
* Add the a.c. compressor. This would involve getting the correct engine accessory bracket from a salvage yard, along with the correct tensioner and idler pulleys for that bracket. Get the proper serpentine belt too. You would also need to make sure you had the proper connections (wiring harness and hoses) for the alternator and power steering units - since they may be in different positions on a car having a.c. versus one not having a.c. You would need the refrigerant hoses involved. Dont re-use old tensioner or idler pulleys; get new one with new bearings in them.
Since the wiring harness for the car would probably not have the wires for the a.c. (though it might have them hanging there anyway) you would have to wire up the circuits to turn on the a.c. compressor, along with the radiator fan, and include the high-pressure cutoff and low pressure cut-off sensors.
* Adding the condenser in front of the radiator would be one of the easy steps.
* If I were going to be doing this much work on an Escort, I would probably replace the timing belt, its tensioner pulley and the water pump while I had things partly dismantled. On mine the lower radiator hose connects to the water pump, inside the engine accessory bracket - and is miserable to reach unless you have removed the p.s. pump and alternator and a.c. hoses! Then you could forget about it for at least 60,000 miles.
Any work you do on your car, you should make a note of what was done, with the date and mileage. This will increase the price you get when you want to sell it, or just make it easier to keep up the maintenance.
If the car did have a.c. it may still have its evaporator under the dashboard. Then I would wonder if the openings in the tubes were capped off. If they werent you will be dealing with corrosion inside the evaporator, and will need to be a careful flushing and evacuation before recharging.
Even if you do move to another Escort having an a.c. already installed, be prepared to spend $$ to get that a.c. working again. A ten year old a.c. system will likely need a rebuilt compressor (or it will leak from the input shaft seal), and possibly new refrigerant hoses, as well as the new receiver/drier of course. My Escort is a 92, so its a.c. uses the old R-12 refrigerant, and doesnt work anymore. If I were going to fix it up, I would certainly convert to R-134. R-12 is too expensive, and the 'alternate' refrigerants are mostly illegal. And new refrigerant hoses would be a very good idea. R-134 operates at higher pressures than R-12.
You should spend time reading in the forums and the FAQ at www.ackits.com. Its the closest thing I know of for guidance on working on the auto a.c. system.
Old 07-03-2007, 08:27 AM
paqman's Avatar
Wow, thanks for the detailed reply. That helps a bunch. Sounds like I need to seriously find out if it ever had one before. If it didn't, I won't even consider it. I've driven it for 4 years without AC, and can live without it. And I don't think I'd consider getting into another Escort only to use this gem of a car for spare parts. It's really just my A2B car, but the maintenance on it has been little to none and I love it.
If I find out it DID used to have AC, I might think about looking further into it, as I really think this car could have another 150K miles or more left in her. Odometer reads 117K, but engine only has 40K on it now. A friend of mine seemed to think it wouldn't be too hard for him, so if it used to have AC, I could round up the parts and he could help me put it in. But you have been extremely helpful. Thanks!
Current Vehicles:
Goners
Old 08-15-2007, 10:11 AM
paqman's Avatar
Hey, I just realized, I wanted to ask you all if there is any way of telling if this car once had A/C in it. Any telltale signs that would let me know?
Current Vehicles:
Goners
Old 08-15-2007, 11:08 AM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
If someone REMOVED the AC, I can't see a reason why they would change the switch on the dash unless for cosmetic reasons. I would expect to find the AC switch still on the panel if the system had been removed. The wiring to it may even still be attached to the harness in the engine.
Old 08-15-2007, 12:16 PM
12Ounce 12Ounce is offline
The biggest clue that I would look for is: The evap coil ... does it exist?
The evap coil is the hardest component to put in place ... and the hardest to remove. If during an engine rebuild, a person decided to remove the ac system ... it is very likely he would not go to the effort to remove the evap coil. Assuming the condensor, compressor, and all the refrigerant tubing has been removed, I'd bet big bucks that the unused fittings for the evap coil are still visible, poking thru the engine side of the firewall ... not too far from the heater coil hoses.
Old 08-16-2007, 06:41 PM
carlos80 carlos80 is offline
Sounds like you re going through too much trouble. Why don't you just buy a car with A/C in it?
