Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-02-2007, 06:57 PM
buckeyerider buckeyerider is offline
Exclamation 96 Ltc Won't Turn Over
I had this car for abt a month in the beginning it started with no problem....one day it all stop, it will crank but will not turn over.... i check the battery and wiring off the battery, i check to see if the fuel pump switch in the trunk was trip, i switch out the fuel relay and nothing happen. Iam not sure if it is a problem with the starter...but i believe it most likely have something to do with the fuel system, exactly where... i am not sure...i need som1 to point me in the right direction and/or give me some insight for a solution to my problem.
Old 07-03-2007, 11:59 AM
mickha2 mickha2 is offline
Re: 96 Ltc Won't Turn Over
1 check fuel pressure
2 check for spark
Old 07-04-2007, 05:04 AM
ltdltc ltdltc is offline
Check your EEC Relay its right next to the fuel pump relay. I had a similar problem on mine that happened for a few months and thought it was the fuel pump as well. Swapped the Fuel & EEC relay and vroom no more starting problems.
Richard
1995 Lincoln Town Car Signature Series
Past
1992 Lincoln Town Car Cartier Designer Series
1992 Lincoln Town Car Executive Series
1990 Lincoln Town Car
Old 07-05-2007, 07:51 PM
Dmartin_1 Dmartin_1 is offline
Question Re: 96 Ltc Won't Turn Over
[quote=buckeyerider]
[/QUO
