Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 07-02-2007, 04:41 PM
Kybar Kybar is offline
Exclamation 94 altima timing chain???
When it sets in idle there is a small knocking noise comming from the engine. It goes away as soon as you give it gas but on occasion when you give it gas it just stalls, will run for about 3 minutes and stall out. Any idea's? I just bought this car and would like to get it running again ASAP so any ideas would be a great help!!!
Old 07-06-2007, 11:16 AM
InnerDragon103's Avatar
InnerDragon103 InnerDragon103 is offline
Send a message via AIM to InnerDragon103
Re: 94 altima timing chain???
hoo boy... could be a whole mess of stuff...
manual or automatic transmission? check to make sure your MAF sensor and other sensors are working, check your EGR valve, check your fuel filter and replace it if it hasnt been replaced, maybe clean out your fuel injectors.
do you have a rough idle? where exactly is the noise coming from in the engine? it could be timing chain noise, or (hopefully not) could be a valve... but yea gonna need more info to think of any possible solutions.
~1994 Altima GXE 5 speed~
Current mods:
Short Ram Intake
Tint
8500K headlights
New sound system, 2 12" subs (600W)
Old 07-06-2007, 08:45 PM
automatic transmision, the noise is comming from the front of the engine, but it seems to loud to be a lifter, the fuel filter has been changed, was thinking maybe the PCV valve was bad or plugged, planning on seafoaming it out tommorow and seing how that goes. The noise goes away as soon as you touch the throttle though, so im really lost
Old 07-15-2007, 01:03 AM
THEFARELANEMAN THEFARELANEMAN is offline
The noise ,may be from the power stearing pump or the chain guide . Does it change when you rock the steering wheel back and forth?
Old 07-24-2007, 07:14 PM
no, its right at the front left corner of cyl 4. and now im finding oil ontop of the spark plugs in cyl 3&4 so something is definetly up, it runs great other then that noise, but really wanna get it fixed before the turbo gets here
