Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 07-02-2007, 11:43 AM
sblake6158 sblake6158 is offline
96 Aurora-Thought it was a Rod Knock
Was driving yeterday and out of know where my 4.0 went to knocking, sounded mettalic. I stopped at gas station, checked oil level, it was fine. Cranked back up oil pressure was around 18 PSI at idle and with 237K miles actually pretty good. Shut car off again as it was still knocking at idle. Walked across street to shop and asked mechanic if he had time to listen to it. Probably 10 minutes went by. He walked across street with me, I started it up and......NO KNOCK...what in the world happened. I drove the car home about 40 miles, got in this morning drove 25 miles to work, NO KNOCK. Please help me understand what happened here...besides a miracle...Thank you and if it was a miracle...Thank you Lord
Old 07-06-2007, 10:07 PM
crash*medic crash*medic is offline
Re: 96 Aurora-Thought it was a Rod Knock
Could be the ac compressor. Mine was knocking before the compressor went and then stopped after the clutch fried.
Old 07-09-2007, 01:47 PM
chrisinsurance chrisinsurance is offline
I just had to AC fixed on my 95. The clutch locked up. Car woouldn't start. Had it towed. The total cost was $560. Mine had a grinding sound almost like metal on metal. Get it fixed quick....
Old 07-09-2007, 02:04 PM
pamla777 pamla777 is offline
Send a message via Yahoo to pamla777
Help Please..i Have A 1995 Aurora And Yesterday I Turned The Ignition Off And The Ac Fan Kept Blowing.we Did Everthing We Could Think Of..taking Out The Fuses ,called The Dealer,etc Nothing Worked. We Had To Disconnect The Battery Ground Cable.this Morning After We Reconnected It..the Fans Will Not Come On At All! Help Please...i Want To Blow The Car Up!!! There Is No Support At All At Customer Service..they Just Scratch Their Heads And Say They Have No Idea.. Thanks..pamla
Old 08-02-2007, 07:26 PM
Retro-D Retro-D is offline
You still have a dealer in your area? They all took off around here like a bat out of hell (Way to go GM). As I recall when I still had my Aurora the fans did stay on awhile when the engine was off on hot days. Also the fans will not come on till the engine needs cooling or the air is turned on. If all else fails try replacing the two relays 'A' & 'B' in the rt front underhood relay center.. The PCM controls the relays and the design on the 95’s is a strange series-parallel arrangement for low speed - hi speed.
RD
