| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
I've done some searching around, but I can't seem to find a good answer for this. How do you know when the clutch master or slave cylinders are going out? I've got a problem (which I won't explain because then everyone will say ya replace them), but I need to know what the symptoms are of this. Thanks yo.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: Slave/master cylinder problem?
They both leak when they go bad. So I would assume if they aren't leaking then they are fine. Whats your problem?
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
the clutch will be real easy to engage
95 talon tsi awd 99 oldsmobile intrigue (dd) |
The clutch pedal will be easy to press. The clutch will not DISengage if either one doesn't work.
Basically, I've had this problem with the old clutch/tranny, and now it's happening with the new one also. What happens is say I'm at a stop. I put it in first and start letting off the clutch (no gas). The car starts rolling, and then it starts shaking badly. It feels like the clutch isn't holding, but I know that's not true. It's brand new. It happens worse in the same situation, but if I give it gas then. It's hard to explain really. It starts jerking until the clutch is fully let go of. It feels weird. Any ideas on what this is?
Again, I just got a rebuilt tranny and new clutch kit (with TOB). It did it before too. It just started doing it all the time now. Ideas? I need this fixed.
My car likes to do similar things. If you try to go real slow in first, just a little bit of gas the car will start to jerk like hell and I have to push the clutch in to stop it. I think it may just be something you have to deal with. My car also does it in 4th and 5th in low rpms.
But it's been happening more and more. Before was just every now and then. Usually would do it when cold. Now it happens all the time. Any ideas here?
I checked my clutch fluid and it looked low, so I filled it up, and it seemed to stop the problem. Did it alittle when I first started up, but then entirely went away. So it seems it may jsut be because of the low clutch fluid.
Now the question is... why is the clutch fluid low? (Insert horror sound here)
hi im not trying to be a thread steeler, i have a 90 talon tsi and i have the same problem, no clutch pedal, real easy to push and it wont return up, it just sits at the floor, i thought it was the slave cylinder so i replaced it and that was not it, i dont see any leeking around the master or anywhere else, could it be the release bearing(throw out bearing?) in the tranie? any ideas guys? thanks
1998 ford zx2: bomz cold air intake 2 baja 12" subs 250 no name amp sony head unit 1990 eagle talon: mods to come |
Not even close to the problem I had in the original post. Nowhere even close. Why didn't you just create a new thread?
You've got a bigger problem on hand.
well its the same subject" clutch"
I'm a little late, but I've been traveling for work a lot lately. Anyway, I would bet that if you stick your head under the dash, you will find your missing clutch fluid on the carpet.
Check both the master and the slave for leakage. When you check the slave, you have to pull back the rubber boot. If it's wet at all, it needs to be replaced.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Ok, so the clutch reservoir is actually cracked on the bottom, causing it to lose pressure and leak from the reservoir itself. I need a new one, but in the mean time, just patching it up for now. But that was the problem.
