Go Back   Automotive Forums Car Chat > Buick > Century
Old 07-01-2007, 07:51 PM
Cowboy34 Cowboy34 is offline
Question Need help on Changing a thermostate on a 89 Centruy w/3.3 V6
I have just changed the water pump and now i have to change the thermostate and their is all of the fule injection over top of the housing,,What all do i need to remove to be able to change the thermostate???Help!!I have to change this out in the morning so i can get on the road to pay my bills!!!
Old 07-05-2007, 05:45 PM
Question Re: Need help on Changing a thermostate on a 89 Centruy w/3.3 V6
well so far i have replaced the water pump,thernostate and radiator and it still heats up and i also noticed the fan does not come on when the motor gets really hot so,, how can i check to see if it is the electricx fan???
Old 07-09-2007, 11:02 PM
Unhappy Re: Need help on Changing a thermostate on a 89 Centruy w/3.3 V6
update,,i have changed the thermostate,water pump,radiator,fan relay and the fan switch on the motor and it still bowl over..What is going on with this motor?????
Old 07-10-2007, 11:48 AM
kurfbird kurfbird is offline
Are you getting bubbles in the radiator bottle or radiator its self. Might be a blown head gasket. Also check for water in the oil or oil in the water. Can be a sign of a blown head gasket also. But does not always have to be present.
Go to a junk yard and get a fan plug from a car. The hook it up the the battery. See if your fan comes on.
Old 07-10-2007, 11:58 AM
the water and antifreeze in the jug and radiator has to keep being filled up because it gurgles(the sound it makes) and the head gasket is not blown,no water in the oil,,,the fan works but is still getting hott
Old 07-10-2007, 12:19 PM
Does not always have to have water in the oil or oil in the water. I have had two cars that had blown head gaskets. ANd the water and oil were clean. Run the engine with the pressure cap on. Is there bubbles in the radiator reservior as it runs and warms up?? If ther is its probably a head gasket.
By your diecription it sounds like a head gasket. Check your spark plugs
You can also remove all spark plugs put carboard uder them. Crank the engine and see if water shoots out. If it does its a head gasket.
Also flush and block it coudl be pluged with dirt and debree cuaisng the engine to overheat
