Old 07-01-2007, 04:08 PM
TaurusKing TaurusKing is offline
squeak
I have an annoying squeak somewhere in my left front end, 94 Taurus.. if I turn the wheel, it squeaks, push down it squeaks... I've tried using my stethoscope to narrow it down, but it's real sensitive and I can't seem to pinpoint using it.. I'm thinking possibly the strut itself is the culprit,, seeing as it happens both turning the wheel and compressing it... I was thinking of injecting some grease into the lower ball joint and the tie-rod end to see if I could eliminate those two options...anyone have any problems with doing that??? All front-end parts are tight.. I've used some wd40 on most rubber parts, swaybar links, bushings, lower ball joint bushings, etc. with no change..
Old 07-01-2007, 07:25 PM
RickMN RickMN is offline
Re: squeak
You can try it on the tire rod end and ball joint, but if it solves the squeak problem, then they have to be replaced. In other words, if they're squeaking that loud, grease is only a temporary fix. They're shot. The other possibility is a bad strut mount.
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
Old 07-01-2007, 10:37 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: squeak
Agreed. Experienced quite a few noisy ball joints on Fords of this vintage. I narrow it down the same way, poke a small hole in the rubber boot, insert the straw from spray lithium grease, and jounce the front end a few times. If the noise changes, I've located the noisy part.
-Rod
Old 07-03-2007, 09:41 AM
ilLUMINAteddriver ilLUMINAteddriver is offline
Re: squeak
I was told the squeak in my 97 was from a bad strut mount, haven't fixed it yet. I do know that I need new struts because now I've got a wheeze going over some of the floatier bumps. Could be one, could be all of the above. Try the hole-poke fix first, then move up to the more expensive fix. Good luck!
