Old 07-01-2007, 01:56 PM
mgday mgday is offline
Send a message via Yahoo to mgday
I Hate Newer Cars !!! Help
My wife has a 1993 Ford Escort Wagon with the 1.9 L engine. I keep replacing starters in it but, now, the cooling fan has stopped working.. Yes, I tested it off the batt and it runs. Where is the sensor and/or relay to make it play?
My car is a 1983 Mercedes Diesel. 301,000 miles and it still plays @ 41 mpg. Plus, it is easy to work on..NO COMPUTERS!!!!
HELLLLLLLLLLLP!!
Old 07-01-2007, 02:09 PM
JStumpalump150's Avatar
JStumpalump150 JStumpalump150 is offline
Re: I Hate Newer Cars !!! Help
the right forum would help. how come people always manage to post the wrong stuff in the cavalier forum???
2002 Nissan Sentra SE-R Spec V w/6 Speed Manual
Old 07-01-2007, 02:17 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
blows my mind as well
Old 07-01-2007, 05:03 PM
DeadBlade89's Avatar
DeadBlade89 DeadBlade89 is offline
Send a message via AIM to DeadBlade89
I posted it in the ford forums for you and heres the response I got...
Originally Posted by mightymoose_22
Follow the heater hose from the firewall toward the thermostat. In this hose you will fine two sensors close to the thermostat end. The sensor that is closest to the thermostat is the one that sends the signal to the PCM to operate the fan.
There are also two relays (high and low) located beneath the air cleaner box.
If the car has AC, turn on the AC and see if the fan kicks in. If it does not, then the problem is likely in the relays. If the fan does turn on, then the temp sensor is likely kaput.
I am not certain what will happen if you disconnect the plug for this sensor... it may cause the computer to think the engine is hot and turn the fan on.
your welcome.
2000 Pontiac Sunfire SE
Originally Posted by freakray
You're right, I actually own a '94 Civic, I just put Subaru badges on it and make the turbo noises as I drive down the road to fool other people.
