Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-02-2002, 08:29 AM
slikk's Avatar
slikk slikk is offline
Send a message via AIM to slikk Send a message via Yahoo to slikk
Question help!!
my yet to be riced 91 prelude has two issues that i need to sort oout before furthur rice-ing.
1. it idles at 2000RPM ... what could be the cause of that and how do i correct it?
2. i think something is wrong with the altinater... if i sit too long the idle RPM varies from 1500 - 2000 .. the drop in RPM is random. could that really be an altinater issue? also if i start the car then disconnect the battery lead while it is running it runs for a little (about 5 - 10 seconds) then shuts off.i was told that once the car starts if the battery leads are disconnected the car shold still run until you turn it off.
--drive it like you stole it--
Old 11-04-2002, 11:53 AM
The-Pro The-Pro is offline
No disclaimer for this info. I am just offering a suggestion.
1. Buy some freaking huge cams and enjoy the high idle . But otherwise, that is a problem and it needs to be fixed.
2. That does sound like a alternator problem. I had a friend whose car did something similar. And the battery, once the car is started, is unneccesary. The alternator will sense that the battery is full (disconnected) and won't feed any power to the battery. This says to me, that the car is half running off power from the battery. Go to the local junkyard and pull yourself a alternator.
1995 Integra LS w/GS-R engine and ITR tranny
1997 GMC Yukon 4dr 4x4 to tow the integra from show to show
