Old 07-01-2007, 11:11 AM
stinkyone stinkyone is offline
lifting engine
How do you lift the engine up about an inch to change the oil cooler line
Old 07-01-2007, 11:31 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: lifting engine
I do not think you have to raise engine to do that.
What year make and model and what engine and transmission and type of oil filter set up?
MT
MT
Old 07-01-2007, 12:21 PM
Re: lifting engine
1996 gmc jimmy 4dr 4.3 v6
Old 07-01-2007, 12:25 PM
MT-2500's Avatar
AF - Advisor
Re: lifting engine
Engine does not have to come up.
Removing drive shaft may help get to it.
Good luck.
MT
MT
Old 07-01-2007, 01:07 PM
Re: lifting engine
ok i got it out but now i have a problem the dorman replacement doesn't fit like the oe one that came out because at the end where it would connect is angled different from the oe one and it won't line up. do you think it could be a manufacturing error, should i just get one from the dealer
Old 07-01-2007, 01:23 PM
MT-2500's Avatar
AF - Advisor
Re: lifting engine
Hard to say.
If you already have a dorman take it back and see if they have the right one.
Also some parts places can make them up for you.
Or if all else fails give you GM parts dealer your vin no and they can fix you up with the right one.
Good luck
MT
MT
Old 07-01-2007, 01:33 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: lifting engine
I'd suggest going with the Dormans if you can. You'll need to make sure that they gave you the right ones. There are 2 for the 4wd and 1 for the 2wd. All 3 are different, and the parts places usually aren't too concerned about giving you the right ones. I've had Advance Auto give me the wrong ones several times, and even misordered them repeatedly.
Old 07-02-2007, 12:17 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: lifting engine
I agree. In this case getting OE may not be the best. Dorman lines seem to be better, just make sure you got the right ones.
Old 07-02-2007, 07:55 AM
warrior_333 warrior_333 is offline
Re: lifting engine
he said hes already got them look at post number 5
Old 07-02-2007, 08:30 AM
blazee's Avatar
Problem?
Re: lifting engine
He said that the set they gave him didn't fit and asked about buying from the dealer. Look at post number 5.
