Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-30-2007, 09:05 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
Tranny Info?
I have a 1993 cutlass supreme SL with the 3.1L V6, does anyone know where i can get a new/rebuilt/good condition tranny (4T60-E) and either way how hard would it be to replace it. i know i have to drop the whole subframe and lift the car up, but what exactly would i need to do. is there a way where i dont have to disconnect everything? The reason i ask is because my current tranny is noisy, It works 100% fine. no problems. except its got a whine in P and N, and while driving through the first 3 gears that i can hear, and now i have a horrible rattle when i turn right. and im fairly sure that its coming from the tranny. something inside.
Also does anyone know how hard it will be to re-build it myself. i found several rebuild kits. but those are mostly seals and such. and i dont know about the pump or the gears or anything...any help from anyone would be Great!!!
Thanks guys...later
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
Old 07-01-2007, 12:49 AM
3100MPFI 3100MPFI is offline
Send a message via AIM to 3100MPFI Send a message via MSN to 3100MPFI
Re: Tranny Info?
a rattle when turning sounds more like a bad AXLE.
A whine at park and neutral also sounds more like low fluid than anything.
Check your fluid levels, then take a look at the boots on the axles. If any of them have breaks or tears in there (look for grease on the subframe), then the axle needs to be replaced.
I also got some clicking noises at one time and it was the WHEEL BEARING.
Check the little things before you assume it is the big things. If it can save you $1500 for a rebuild, then it is worth it.
Old 07-01-2007, 12:12 PM
XGamesJ6's Avatar
Re: Tranny Info?
im pretty sure the Axles are fine, i checked them not to long ago, both sides are fine, boots are in good condition, and theres no play in the axle itself. So i ruled those out, my right side wheel bearing has some play in it however, but there is no noise from it, unless thats what it is when im turning. i plan to replace that anyways. Fluid levels are all perfect, everything is tip top, including tranny. Im pretty sure the pump has problems, like bad seals or something.
