Old 06-30-2007, 08:08 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
A/F ratio gauge?
I need help hooking up my A/F gauge it is a narrow band should i use the ECU or actual sensor and if ecu should i go with the front or rear sensor HELP.
Old 06-30-2007, 10:45 PM
Ronnie_1981 Ronnie_1981 is offline
Re: A/F ratio gauge?
got it stealth316 and my manual helped.....
Old 07-01-2007, 09:36 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i wouldn't even waste my money on a A/F gauge if you still have the narrowband O2 sensor. if you want to monitor A/F with a narrowband, just get a datalogger and monitor your O2 voltage. if you REALLY wanna know the actual A/F (read = fine tuning), get a wideband O2 sensor.
here's a good thread on comparing different Widebands O2 sensors: their accuracy, reliability, software, etc.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-02-2007, 07:44 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
How to install narrowband A/F
step one, open package
step two, look at the guage and imagine all the pretty lights that will be flashing
step three, realize that all those pretty lights wont really tell you anything
step four, throw worthless piece of shit gauge in the garbage and try not to waist money on stupid blinking lights anymore.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 07-02-2007, 07:57 AM
vectorspecialist vectorspecialist is offline
o if only there was a way to hook it up to the cristmas tree or something, it would make a great deceration.(no offense to those that arent cristian)
yup, here i am
Old 07-02-2007, 10:00 AM
christmas trees aren't christian anyways, they are pagan, just like the easter bunny
Old 07-02-2007, 10:25 AM
Linebckr49's Avatar
i see you've read Struggly's installation procedure for the Venom ECU.
93 3000GT base
Old 07-02-2007, 11:07 AM
Well no I hadn't, but thats quite awesome also.
