Go Back   Automotive Forums Car Chat > Ford > Contour
Old 06-30-2007, 05:44 PM
Stabinsky Stabinsky is offline
Unhappy '99 Contour in serious trouble, dont know what else to check
I own a 1999 Ford Contour, and it is breaking down. When I try to dive it, any time i press the accelerator, it bucks wildly and tries to down shift. I realize this could mean one of thousands of things, but let me tell you what I have already done. I checked the Throttle Position Sensor, and replaced it, I replaced the fuel filter, there was about a half inch of oil in two of the four spark plug holes, so i removed them, regaped them, and cleaned them, but that caused the engine to start smoking. I have ruled out trouble with the transmission because the engine does this when i gas it in park/neutral. I also checked the fuel pump, and it sounds like its staying on for as long as it should and turning off when it should. I recently put about a gallon of gas into it from one of the cans we keep in the barn (i thought it was empty, but it had a full tank of gas) So i was thinking it might have been some old or bad gas. If someone could please point me in the right direction, it would be greatly appriciated. I am unable to take it to the shop because i live 30 miles out of town, and I really dont want to risk driving it that far
Old 07-02-2007, 10:40 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: '99 Contour in serious trouble, dont know what else to check
Sounds like your valve cover spark plug gaskets are bad. I cant imagine a car would run very well since oil covered all over spark plugs.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-07-2007, 05:28 PM
ChevySSNaples ChevySSNaples is offline
Im not a expert and i have not had that problem with the contour but i had that similar problem with my corvette, if the fuel is good maybe the fuel injectors are clogged?
