Old 06-30-2007, 10:21 AM
dsa/ankers dsa/ankers is offline
2000 blazer runing problems in hot weather
i have a 2000 blazer in hot weather after driving for maybe 30 miles it starts to loose power and finally it stalls out and won't restart until it cools down for a few hours it has a new the fuel pump wires,cap,rotor,plugs,wires,and are only two months old and i istalled a gasket w/screen on the egr valve any suggestions would help.
Old 07-01-2007, 09:34 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 blazer runing problems in hot weather
When it quits check for lose of spark or lose of fuel pressure.
What engine?
What mileage and mileage of last tune up?
Any check engine lights or codes?
Is the engine getting hot?
How is that fuel filter?
I would hook up a fuel pressure gauge to it when you are driving and watch for lose of fuel when it quits and go from there.
Then when it quits check for lose of good hot blue park to plugs.
MT
Old 07-02-2007, 04:01 PM
it is a 4.3 i just tuned it up a few months ago w/fuel filter no codes does not trip the service engine light it's not running hot but i do need a fuel pressure gauge. getting spark getting fuel getting tired of this truck.
Old 07-03-2007, 04:25 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
This sounds like my old 93 S-10. It was the ignition Module. It had the internal Ignition Module (inside the distributor) but I believe the 2000 has a different design. Anyway it would die after it got hot. The Parts Counter guys tried to tell me that these things either work or they don't and the heat has nothing to do with it. Bull! The problem went away after I changed it out. Now before you run down and buy a new Module, get yours tested.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 07-06-2007, 11:16 PM
Master.ASE Master.ASE is offline
Take your fuel filter off after driving for 15 minutes. poor the gas out of the filter in a glass from the in side. is it nasty like rust? if the fuel pump was replaced without the fuel filter then you will burn up the new pump. Also if you have a w engine code, your screen around your injector could be clogged.I Just fixed a blazer that the dealership couldnt fix and a whole panel of master techs couldnt. The screan was clogged but you couldnt tell unless you blew through it. Also replace the screan on the fuel pump. a pump must have volume and pressure. not just pressure.runaround
Old 07-06-2007, 11:20 PM
Try the regulator and also the screan around the injector. Questions on checking it, ask me. I can fix any thing with wheels
