Go Back   Automotive Forums Car Chat > Buick > Regal
Old 06-30-2007, 01:36 AM
sblg43 sblg43 is offline
Can I change keyless fobs to another car?
I currently own a 1996 Regal Custom with keyless entry and two working fobs. It has 200K on it and is starting to require more maintenance that I think it's worth. I went car shopping and found a 1996 Regal GS with half the miles, leather seats, moonroof, etc... BUT the dealer only had one key and no fobs. What I would like to do is use the fobs from the other car on this new one. I can only assume that it is keyless entry capable ( I don't know how to find out for sure.) I found a couple of programming options on this forum and will try them out. Are there any words of wisdom that I should know before I try this?
Thanks all.
Old 06-30-2007, 02:41 AM
Re: Can I change keyless fobs to another car?
It seems that I was successful.
As mentioned in this forum, the wire in the trunk did the trick. I tried both fobs one at a time and when one would work the other would stop working and vice versa. I even put one in the basement at the far side of the house so no signal could reach it, but it still didn't work after I brought it up. What did work was when I grounded the wire, let the locks cycle through, then pressed a button on both remotes at the same time. Now they both work great, and with both cars at the same time!
Old 06-30-2007, 03:34 PM
suren suren is offline
Did you grounded the wire on both cars and which wire in trunk you talking
about. Your findings are interesting.
