Go Back   Automotive Forums Car Chat > Datsun > Roadster
Old 11-02-2002, 12:42 AM
angelot angelot is offline
Question Datsun 2000 Brakes
I need help!!
I have a 69 2000 Roadster. After I drive it a while, the front calipers lock and the pedal stays hard at the top. After sitting a couple of minutes they free but then lock up again after a few applications of the brake. I put new master cylinder, front calipers, rear cylinders and pads all around and again....same problem. ANy suggestions???
Old 08-11-2003, 05:24 PM
jon602 jon602 is offline
There's not much left except the proportioning valve. or you could have a pinched line. The pedal pressure would push the fluid through quickly and then take awhile to flow back to the resevoir. Do both calipers lock up or just one?
Old 08-11-2003, 11:38 PM
Thanks Jon for the reply. I replaced every part of the system except the 3 rubber hoses on the front. Still had the problem, Finally replaced the 3 hoses and VOILA!!! no problem. Sort of an expensive lesson. IT seems the hoses were old thus collapsing when the pedal was released.
Well, after replacing everything, I am going to be set for a long time on brakes.
2000 5.3L Silverado brake system is weak but everything is new Silverado_Dude Silverado 1 06-14-2010 07:12 AM
2000 cougar brake switch. HELP! MKO1988 Cougar 0 06-09-2010 09:38 PM
2000 blazer / jimmy brake bleeding issue rmwilson Problem Diagnosis 11 12-16-2009 10:14 PM
Rear Brakes 2000 Bravada bbusha Bravada 1 09-15-2009 06:59 PM
'69 Datsun 2000 brakes epabrown Roadster 0 08-12-2007 04:35 PM
