Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-29-2007, 11:55 PM
umina umina is offline
Radio compatibility
my 97 bonny has a cheapo sony deck in it and it sucks. I want to change to something else, or even back to stock, but not sure what will be compatible. What is compatible within the GM family of cars, just pontiac radios, or will a buick or olds stereo head unit from the same year fit? Also, is this a double din, or 1.5x din sized radio? Thanks !!
Old 06-30-2007, 09:18 AM
ChemMan ChemMan is offline
Re: Radio compatibility
The original stock radio was a 1.5 DIN unit i believe. There is an adapter available to put any standard radio in the dash. As far as I know, you can only put the same OEM radio back in, or any aftermarket, as long as it fits.
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 06-30-2007, 10:41 AM
Thanks for the reply. What about using a CD head unit from a Chevy lumina? I looked at some on ebay, and the connectors on the rear look to be the same. If it plugs in, will it work, or is there something different with the theftlock setup? I swear when i was looking at used cars awhile ago, i saw a Pontiac Montana minivan with the chevy venture head unit installed, maybe i was just seeing things. I like the chevy one because it shows more info onscreen and doesn't look as cheapo looking as the pontiac stock one.
Chevy
http://cgi.ebay.com/ebaymotors/CHEVR...QQcmdZViewItem
Pontiac
http://cgi.ebay.com/ebaymotors/PONTI...QQcmdZViewItem
Old 06-30-2007, 04:00 PM
It might work, I just have no idea. You would have to get a wiring diagram of both radios and compare them to see if it would work.
Old 06-30-2007, 04:03 PM
OK, looking at the two auctions, they MIGHT be interchangeable. It looks as though the connectors are the same, but the mounting ears are slightly different between the two, which might be the killer.
Old 07-14-2007, 02:19 PM
bungea bungea is offline
i have a stock cassette player for a 95 pontiac bonneville,( sheboygan,wi)
