Old 06-29-2007, 07:04 PM
sbiddle sbiddle is offline
Daylight running lights not working
This is a '99 1.3 liter automatic. The little green light on the dash works correctly and it shuts off when the parking break is applied but the headlights aren't on like they should be. The other light functions are normal.
Any idea where to look for this problem? Does anyone have a wiring diagram that shows this circuit? The Haynes manual is absolutely useless.
Thanks!
Old 07-01-2007, 10:14 AM
Mike_Van Mike_Van is offline
Re: Daylight running lights not working
Are you saying that you expect the DRLs to remain ON when you have a the parking brake ON?
Mine turn OFF when the brake is ON, and turn ON again when I take the brake OFF. I thought that was normal...
1999.5 Golf 1.9 l TDI, 5 spd., 154k mi., Panzer Plate, B20, FrostHeater
2007 Passat 2.0 l TFSI, Auto, 83k mi.
Old 07-01-2007, 02:00 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
make sure the bulbs are good
Old 07-01-2007, 03:26 PM
The DLR system is supposed to turn the low beams on whenever the engine is running and if the parking brake is NOT on. My DLR indicator on the dash, the little green light, comes on normally, but the headlights don't respond.
Now I've done a little internet searching and found that for earlier Metro's, like '91, there is a control box under under the dash near the steering column and a resistor behind the splash guard of the left quarter panel.
So, I looked under the splash guard and there is nothing there at all. No resistor. I did find the control module, but it's different than described with the earlier models. It's a silver box labelled '38660-50G00' made by Omron.
Questions: 1. Where might the resistor be located on a '99?
2. Does anyone have a 38660-50G00 they'd be willing to part with?
Thanks!
Old 07-03-2007, 11:56 AM
I think that later Metro models didn't have a DRL resistor. Anyone concur with this? The Haynes manual is useless on the subject.
Old 07-07-2007, 02:20 PM
Anyone who can help here? i visited the junkyard today and the DRL module on a '96 is black and has more wires going to it. The one I need is silver.
Old 07-08-2007, 11:27 AM
I know little about the '99. You might also try posting a question on the Swift (the Geo's twin) forum...
http://teamswift.net/
Old 07-09-2007, 06:09 AM
My thoughts exactly... I registered with teamswift a couple of days ago but they haven't authorized me yet... does that usually take a long time?
Old 07-09-2007, 07:04 AM
michael_lindsay2 michael_lindsay2 is offline
I have a 95 metro. when i apply the parking brake the green light goes off an so does the drl until i release the brake. then it works fine. i think its suppose to do that.
Old 07-11-2007, 11:12 PM
sas95 sas95 is offline
I'll type in the System Check chart for Daytime Running Lamps (DRL) out of my '95 manual. It's a first step - helps isolate the problem.
Action 1: Turn light switch to HEAD position;move dimmer switch to LO position
Normal Results 1: Both LH and RH low beam filaments are lit at normal low beam intensity.
Action 2: Move dimmer switch forware to "HI" position
Normal Results 2: Both LH and RH low beam filaments turn OFF. Both LH and RH high beam filaments turn OFF. Both LH and RH high beam filaments are lit. High Beam Indicator is lit.
Action 3: Move dimmer switch rearward to "PASS" position.
Normal Results 3: both LH and RH high beam filaments are lit. High beam indicator is lit.
Action 4: Turn light switch to OFF or PARK position.; start engine; disengage parking brake.
Normal Results 4: Both LH and RH low beam and high beam filaments turn OFF. High beam indicator is OFF. Both LH and RH low beam filaments are lit at 80% intntensity. DRL indicator is lit.
Action 5: move dimmer switch rearward to PASS position.
Normal Results 5: both LH and RH low beam filaments turn OFF. DRL indicator is OFF. Both LH and RH high beam filaments are lit. High beam indicator is lit.
Action 6: shut off engine; disengage parking brake.
Normal Results 6: all headlamps turn OFF.
Circuit Operation:
The headlamps are controlled either by the daytime running lamps (DRL) control module or by the light switch/dimmer switch. Once the light switch has been turned to HEAD, the dimmer switch will control the headlamps. WIth the dimmer switch in LO, ground is provided to the low beam filaments through the DRL control module, junction block, dimmer switch, back through the junction block, through the closed contacts of light 2 relay to ground (G201). Since voltage is applied to the headlamps at all times through the H/L LH Fuse and the H/L RH Fuse, the low beam filaments will light.
With the dimmer switch in HI, the high beam filaments in the headlamps are grounded through the junction block, dimmer switch, back through the junction block, through the closed contacts of Light 2 relay to ground (G201). Since voltage is applied to the headlamps at all times through the H/L LH fuse and the H/L RH fuse, the high beam filaments will light. The ground to the high beam indicator is provided in the same manner as the high beam filaments. Since voltage is applied to the high beam indicator at all times through the H/L LH fuse, the indicator will light.
With the dimmer switch in PASS, the high beam filaments in the headlamps are grounded through the junction block and dimmer switch too ground. Since voltage is applied to the headlamps at all times through the H/L LH fuse and the H/L RH fuse, the high beam filaments will light. The ground to the high beam indicator is provided in the same manner as the high beam filaments. Since voltage is applied to the high beam indicator at all times through the H/L LH fuse, the indicator will light.
With the ignition switch in ON or START, voltage is applied to the DRL control module through the IG fuse. The DRL control module is permanently grounded (G201). A number of conditions must be met before the daytime running lamps system will work properly: the parking brake must be disengaged, the DRL control module must not receive a ground signal from the generator (a ground signal from the generator indicates that the generator is not charging the battery) and the light switch is either in OFF or in PARK position. When the parking brake is engaged, the parking brake switch closes, prividing a ground to the DRL control module, disabling DRL operation. When the generator is not running, a switch in the generator closes, providing a ground to the DRL control module, disabling DRL operation. When the light switch is in the HEAD position, a path to ground (G201) is provided to the coil of light 2 relay. Since power is provided to the coil of light 2 relay at all times through diode no. 3, the contacts on the relay close, providing a ground path from the DRL control module to Ground G201, disabling DRL operation.
Once all the listed conditions for DRL operation are met, the DRL control module will provide a ground for the low beam filaments in the headlamps through the daytime running lamps resistor to ground (G102). Since voltage is applied to the headlamps at all times through the H/L LH fuse and the H/L RH fuse, the low beam filaments will light at 80% intensity.
The DRL control module will also provide a ground to the daytime running lamps indicator when the DRL operation conditions are met. Since voltage is applied to the daytime running lamps indicator through the IG fuse, it will light.
Old 07-11-2007, 11:20 PM
Have you checked that your charging system is working? (See previous post.)
Are you getting any Diagnostic Trouble Codes?
The DLR module connector for '95's has 11 wires. How many on yours?
Old 07-12-2007, 07:15 PM
The charging system is OK. Battery stays charged and no alternator light, so I don't think that's an issue.
No trouble codes once I replaced the ignition wires.
I'll check out how many wires in the DRL module connector. This has become my 18 yr old's ride, so I don't get to see it too often. I'll post back when I get a chance to stick my head under the dash.
Old 07-14-2007, 08:17 AM
I checked the number of wires in the DRL harness and there are 8 wires and the box is silver and has this number on it: 38660-50G00
The brake and DRL indicator lights work like they are supposed to, but the low beams don't come on with the engine running and the e-brake off like they are supposed to. Everything else runs great. Any more ideas?
Old 07-14-2007, 08:34 AM
The '95 models have an 11-pin connector. Think they're too different, and circuits too different to draw comparisons for diagnosis. That is, without having the electrical schematics for your year car.
Old 07-14-2007, 09:45 AM
Can someone post a schematic for a '99 Metro DRL circuit?
Thanks!
