Old 06-29-2007, 10:04 AM
antiflag208 antiflag208 is offline
intake for 2.4 L
i was wondering if i could use a cone air filter running right of the intake manifold i know the sensor for the intake would not be hooked up and you would get a check engine light but would u get more air into the engine without all of the restrictions from the air intake pipe
Old 06-29-2007, 10:31 AM
DeadBlade89's Avatar
DeadBlade89 DeadBlade89 is offline
Send a message via AIM to DeadBlade89
Re: intake for 2.4 L
youd be getting more hot air that way
2000 Pontiac Sunfire SE
Originally Posted by freakray
You're right, I actually own a '94 Civic, I just put Subaru badges on it and make the turbo noises as I drive down the road to fool other people.
Old 06-29-2007, 01:18 PM
notaricajustfasta's Avatar
notaricajustfasta notaricajustfasta is offline
Send a message via AIM to notaricajustfasta
|I had my sensor out for like a month and never got and check engine light on my 2.2. and the whole hot air thing.
1998 Cavalier 5 speed: Custom CAI, Ractive Muffler, B&M Short Shifter cut down, new 4-1 header, Pioneer 6700 head unit, Apline Type-R 6x9's on the rear deck powered by an ESA 100 watt amp and Pioneer 4x6's in the doors
1/4 mile: 16.854 @ 80.30 MPH
To Do List: Finish 2.25" exhaust, New clutch
Cheap, Fast, Reliable. Pick two
Old 06-29-2007, 04:13 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
your check engine light would only come on if you unhooked the sensor, if you just pull it out and leave it hanging somewhere, there probably wont be a CEL
also, there will be pretty much no performance gain by doing this since you will be sucking in WAY hotter air then you would be with your stock intake, you may even lose performance
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 06-29-2007, 04:55 PM
Ronnie_1981 Ronnie_1981 is offline
i don't think the hood will close anyways, now cut a hole in the hood and put the filter there you will be ok, but i would recommend buying an intake or making one
Old 07-01-2007, 12:40 AM
shakewell shakewell is offline
There wouldn't be any performance gain. The engine doesn't suffer from lack of intake air so there is no need to "open it up". Unless you plan on doing some heavy modifications to the engine, you're going to end up having less performance because the computer will not be able to adjust your fuel ratio correctly. If we were talking about a v-8 with no engine management computer - and you had a good spot to pull in cold air - then I might tell you to go ahead with it.
