99 taurus moonroof wiring
I have a 99 Taurus with a moonroof. The moonroof was wired to a fuse and was wraped around the terminals. The roof has it's own inline fuses. The wires have been removed from the fuse in the fuse block. I rewired it to the radio fuse.
The problem I am haveing is that the lights for the roof controls do not turn off when the car is shut off. This will eventually drain the battery. Does anyone know what fuse I can attach the moonroof wiring to that will turn off when the car is shut off????? |
Re: 99 taurus moonroof wiring
Hmmm, sounds like a wiring diagram may help you here. If you'd like a copy of the factory wiring diagram, you can send me a private message with your request and an e-mail address for you that can accept PDF attachments. I'll send you the factory wiring diagram for a '98 Taurus that should match your '99 wiring.
-Rod |
