Old 06-29-2007, 04:53 AM
olkevinlo olkevinlo is offline
boring.
does anyone know how wide the cylinders in the stock motor can be bored out? 3000 in a v6 doesn't seem like it's making use of such a large motor. maybe it's just me though. but has anyone bored their's out?
Old 06-29-2007, 06:01 AM
AutostradaVR4 AutostradaVR4 is offline
Re: boring.
well v6 blocks can be different sizes man...just like 4-bangers can be anywhere from 1.3L to 2.5L (like the one in my LeBaron ) doesnt mean a 1.3 can be bored to 2.5.
but anyway, i know IPS sells .55 over pistons...seems like pushing it though. if/when i take that step, im goin with .35 over.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 06-29-2007, 09:36 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: boring.
yeah.. think about it.. 2.7 audi S4's... 4.0 mustang (POS) all 6 cylenders
whats the skyline? 2.6 or 2.7
Old 06-29-2007, 10:43 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Re: boring.
Skylines have had 2.0,2.5, and 2.6 but i common mod/swap is the 3.0 rb custom.
Old 07-01-2007, 09:30 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: boring.
just got confirmation today from some very knowledgeable 3S ppl (Ray Pampena et al). absolute SAFE maximum the 6G72 can be bored to is .120 over. most people will tell you not to go more than .100 over b/c .120 is pushing a very narrow cylinder wall.
you won't make a significant increase in power by boring the cylinder, simply because we cannot bore it very much at all. if you want to increase power at the motor first, go with a higher compression ration piston, port & polished heads, perhaps oversized intake/exhaust valves, and cams.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
