Old 06-29-2007, 12:33 AM
sak22's Avatar
sak22 sak22 is offline
USACMRETVET
89 C1500 A/C Question
How do you jumper the connector on the side of the receiver/drier and when you do will the clutch stay on contantly or will it cycle? The A/C clutch on my 89 C1500 does cycle, but it does it very rapidly... about 2 seconds on then 2 seconds off constantly. I don't ever remember it cycling that fast before. The A/C system has been professionally converted from R12 to R134 about 3 years ago, was fine up to now and currently registers aprroximately 40 PSI at the Low side and blows about 60 degrees F inside the cab... outside ambient temp is 80 degrees F. My thought is that the clutch is cycling so fast that it doesn't stay on long enough to pull in the new charge I put in the system. Was wondering if jumpering the connector on the side of the receiver/drier would make the compressor stay on constantly... at least for a few minutes until it could pull the new charge into the system... then maybe the clutch will start cycling normal. Any help would be appreciated.
2008 Honda CR-V EX-L SE- Glacier Blue Metallic
2007 Honda CR-V EX-L SE- Nighthawk Black Pearl
2003 Honda CR-V EX- Chianti Red Pearl
2002 Chevrolet S-10 LS- Dark Cherry Red Metallic
1989 Chevrolet C1500 Silverado- Custom Black Cherry Metallic
"The Black Beauty"
Old 06-29-2007, 08:42 AM
bigcoconut bigcoconut is offline
Re: 89 C1500 A/C Question
Two things I can think of...
1. Check the low pressure sensor on the accumulator (receiver/dryer). Pull the electrical connection and jumper the wires to see if the compressor runs after that. It should run constant, that is the only fail-safe for the compressor. Don't keep it that way, this means your freon is low or you have a clog in the system.
2. The compressor clutch. I don't know how to jumper the clutch but my friend had a similar problem and it turned out to be the clutch on the compressor, it just wouldn't stay engaged. Yup, new compressor...
"Yes I have a truck and No I won't help you move your stuff..."
2008 Kawasaki KLR650 2500mi (fairweather commuter)
1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver)
1999 Venture 120,000mi (moms vacation bus)
1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw
Old 06-29-2007, 12:28 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
After you get the compressor to run.
Give us your low and high side readings at idle and at 2K.
With one these things.
http://www.ackits.com/merchant.mvc?S...erantGaugeSets
And say no to the one gauge one hose one can stop leak and oil kits death from wall mart.
MT
