Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-28-2007, 07:12 PM
mike561 mike561 is offline
AC and electrical questions
I recharged my AC, i know it has a leak but i want to see how long it will last, i plan on having it fixed when i get the funds, but i noticed my other 88 caprice used to do this as well. the ac will be blowing nice and cold, but under hard acceleration it will blow slightly warm for a few seconds then back to cold, whats up with that? (note my other 88 caprice did NOT have a leak, but still did this) im thinking a vaccum issue maybe? and for the electrical question, what would have to be wired up in order to have the power locks lock automaticly when the car is put into drive, or reaches above a certian speed, and unlock when the engine is shut off like the newer cars have? jus wondering, in case i ever become rich enough to do that...
2006 Chevy Cobalt LS
Old 06-28-2007, 07:15 PM
GreyGoose006 GreyGoose006 is offline
Re: AC and electrical questions
not sure if its related, but 9c1's have a WOT ac cutoff
basically, the ac will cut off at WOT to provide max power for pursuit.
Old 06-28-2007, 07:20 PM
yeah i know mine wouldnt have that since its a civi model, im also thinking it something with the compressor, which i was told needs replacing as well, but the compressor on my 88 was still good though
silicon212's Avatar
silicon212 silicon212 is online now
Confoundingly Lucid
Send a message via ICQ to silicon212
His car isn't a 9C1, although you are absolutely correct. Mostly why I don't run the AC on my car unless someone else is riding with me - gas is expensive and I've put up with 110+ degree summers for 35 of my 38 years so I can squeak by.
When I do want it cool though, that WOT cutoff can be a pain in the posterior. Then again, I drive my car hard, as it was designed for.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-28-2007, 11:26 PM
so even the civi models have a WOT cutoff?
Old 06-29-2007, 12:37 AM
silicon212's Avatar
Confoundingly Lucid
Not that I am aware of. If yours is getting warm at WOT, it's possible there's a vacuum leak in the AC control hoses somewhere. It could also be the orb under the hood - that is hooked up, right?
I'll bet it's still blowing cold air, but instead of through the regular vents, it's coming from the defrost vents.
Old 06-29-2007, 11:10 AM
its comming through the regular vents, and all the functions work when i change from the front vents to floor and to defrost
