Old 06-28-2007, 05:35 PM
swayyde swayyde is offline
brake sensitvity
My Car is a 94 Cavalier,i just got my license a week ago and i was curious about the brake pedal, it seems i almost have to push it to the floor before it even starts to break, i was wondering if there was a way to make it more sensitive.
Thanks Ahead of Time
Old 06-28-2007, 10:31 PM
notaricajustfasta's Avatar
notaricajustfasta notaricajustfasta is offline
Send a message via AIM to notaricajustfasta
Re: brake sensitvity
change the pads
1998 Cavalier 5 speed: Custom CAI, Ractive Muffler, B&M Short Shifter cut down, new 4-1 header, Pioneer 6700 head unit, Apline Type-R 6x9's on the rear deck powered by an ESA 100 watt amp and Pioneer 4x6's in the doors
1/4 mile: 16.854 @ 80.30 MPH
To Do List: Finish 2.25" exhaust, New clutch
Cheap, Fast, Reliable. Pick two
Old 06-28-2007, 11:25 PM
cboyfan2020 cboyfan2020 is offline
i see this everyday....check the master cylinder..if low then pads/shoes are low or you have a hydraulic leak somewhere(caliper/wheel cylinder)....less likely is parking brake very mis adjusted...suggest taking to a shop for full brake system eval
tech w/ 4 yrs exp.
ASE cert in A4, A5, A6, A8
Old 06-29-2007, 07:14 AM
shakewell shakewell is offline
More than likely you need to have the rear brakes adjusted. My advice, if you aren't sure of what's going on and don't know how to check yourself, is to take it to a professional - brakes are pretty darn important.
