Old 06-28-2007, 03:22 PM
feb feb is offline
Need Tire Info
I know this sounds stupid but I need to know what size tire came on a 2000 chevy silverado regular cab. I want to replace some tires on that model truck and what is on there now is 255/70/16. Don't know if that is the correct size or not.
thanks
Old 06-28-2007, 04:17 PM
bigbadram51 bigbadram51 is offline
Re: Need Tire Info
what you have on there is right in between stock sizes. 245 or 265 depending on if it is a Z71 the Z gets a slightly larger tire. I would run a 265/70, or if you want crank your TB's a little and run a 285/70.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 06-28-2007, 04:24 PM
2000CAYukon 2000CAYukon is offline
Re: Need Tire Info
According to carsdirect.com, 255-70-16s was one of the size to come stock on your Truck. See http://www.carsdirect.com/research/s...71A0&year=2000
//2000CAYukon
Old 06-28-2007, 06:15 PM
rjeffery rjeffery is offline
Re: Need Tire Info
I belive 255/70/16 is a factory option. I put 265/75/16s on my 2wd with no rubbing.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 06-28-2007, 07:23 PM
Re: Need Tire Info
The great thing about factory wheels is you can stuff a huge tire in there and if you rub at all, its not much. I have seen guys get 36's or true 35's in there with just a bodylift. With my 20x10's I needed approx. 10 inches of lift to not rub with 35's
3" PA Body Lift
Covermaster Top
