| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
I have a 98 eclipse GST with oem replacement pads and rotors and under heavier braking the back tires lock up usually just one or the other is this common for this car?
Re: Back brakes locking up
Mine does it sometimes. Its just because the back gets light when you slam on the brakes. Does your car have abs?
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
make sure all the air is out of the calipers... an air bubble can push the piston cocked... and cause the brakes to lock...
but if it does this, the rotors will be WAY hot just from normal driving because the pad is always rubbing on the rotor... as for under HARD conditions, the back tires loose weight off them, causing them to slip...
yea its got abs im pretty sure
