Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-28-2007, 07:10 AM
bogart219 bogart219 is offline
Stalls when engine warmed?
Hey guys,
99 olds cutless gl, 3.1 engine, 120k miles. I've read through a bunch of post but am still confused as to what me problem could be. Car starts up fine when cold. It seems after the engine warms up,( going to the store then coming out to leave), the car will start up then stalls. It might do this a couple times then stays running ok. What ever is causing this seems to be affected once the engine warms up. Anyone got any ideas on what I could check for and the order in which I should check. BTW, the car is showing no codes! Thanks for any help!
Old 06-28-2007, 02:36 PM
maxwedge maxwedge is offline
A990 racer
Re: Stalls when engine warmed?
Try cleaning the throttle body and iac , for starters.
Old 06-28-2007, 03:15 PM
/max,
Thanks for the info. That sounds like a good place to start. Can I use carb cleaner once I get those things apart? Thanks again for the help.
Old 06-28-2007, 08:42 PM
Ian Szgatti's Avatar
Ian Szgatti Ian Szgatti is offline
use any product that says.. "oxygen sensor safe" Have a look at your air filter too
Old 06-29-2007, 04:53 AM
Got it. Will clean this weekend. thanks!
