Old 06-27-2007, 11:30 PM
mic329's Avatar
mic329 mic329 is offline
WIP - Mclaren MP4/4
Hello all
I have started the 1/20 MP4/4 since mid of May and here are some pics on it.
Enjoy !!!
Mikusen
Old 06-27-2007, 11:34 PM
mrawl's Avatar
mrawl mrawl is offline
Re: WIP - Mclaren MP4/4
Beautiful clean work and photography. Now, cross your heart and hope to die, was there any photoshopping involved here? (j/k)
Old 06-27-2007, 11:38 PM
klutz_100's Avatar
Old 06-28-2007, 12:56 AM
mic329's Avatar
Thanks you for your comment.
Normally, I use Picasa to shapen those pictures.
Old 06-28-2007, 04:04 AM
stevenoble's Avatar
Looks great so far.Which red did you use?
Steve Noble
Old 06-28-2007, 04:25 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Great job, picts are at a (great) modelling magazine's level.
gio
Old 06-28-2007, 04:46 AM
mic329's Avatar
Thank you Steven. I have used MP4 red by Finisher's (a set of 3 bottles, including foundation white, MP4 red and florescent pink)
btw, I have seem in AF that you have made MP4/5B as well and I have a question on the fitting on the MP4/5B. Do you have any pictures on your MP4/5B showing that the cowl fitting with the monoque.
I have cut the front wing as well and I found that a big gap present in between. Thanks
Old 06-28-2007, 04:48 AM
mic329's Avatar
Thank you very much.
Thank you Picasa as it helps improve the pictures as well.
Old 06-28-2007, 07:26 AM
tehSAC tehSAC is offline
I Cant See The Photos
Old 06-28-2007, 07:54 AM
mic329's Avatar
Now should be okay
Old 06-28-2007, 05:27 PM
stevenoble's Avatar
I used the same Finishers paints on my McLaren MP4/5B.They are very good paints.Regarding the pictures showing the cowl fitting onto the monocoque.I haven't any because the cowl did not fit onto the monocoque due to all the wires and stuff I added to the engine and side pods.The gap at the nose to main cowling join should be easy to take care of though.Fit a small piece of plastic card to the part where you sawed through the joint and file it to shape.This will replace the plastic you removed when you made the cut.
Steve Noble
Old 06-29-2007, 08:25 AM
mic329's Avatar
Thanks Steven
I have checked the monocoque and I found that, unlike MP4/4 which the front nose is lying flat to the surface. For MP4/5B, the front nose is slightly higher and once it is glue to the base plate, the gap will going down and close up.
I have cut under the front nose a bit
and now the gap getting closer
I will use some styrene sheet which cut to strip and glue in between to form the flange on both sides.
Mikusen
Old 06-29-2007, 08:58 AM
billypee's Avatar
billypee billypee is offline
Send a message via AIM to billypee
Great model. Great photos. It looks as though you are already 80% complete!
Kind regards,
Bill
On the workbench:
Completed WIPs:
Completed Models Gallery:
Old 06-29-2007, 09:12 AM
mic329's Avatar
Just start adding tiny details and now prepare for the exhaust pipes
Stay tune !!!
Old 06-29-2007, 06:15 PM
Enzoenvy1's Avatar
Beautiful...............................
