After run the vehicle for a while, it did not start: complete dead: after hour or so, it will start again, this happend during hot period. Any lead on the problem:Thank you, Santiago |
Re: 1996 Dodge Van Ram 2500 Electrical Problem
Do you mean the engine won't fire up or that the starter/engine does not turn?
How are you,
Yes, the engine will not fire up, the starter does not crank: complete silence. Thank you, Santiago |
The solenoid on the starter could be internally cracked which will cause it to expand and bind when hot. As it cools it becomes free and can move. When the solenoid moves it closes a set of contacts powering up the starter. At the very least you probably need to replace the solenoid. But to avoid problems shortly down the road, I suggest you replace the whole starter/solenoid assembly.
I did replace the starter: let see, thank you.
Do you still have the problem with the new starter, or no?
Was there a new solenoid on the starter or are you using the old one? |
