Old 06-27-2007, 12:26 PM
stinkyone stinkyone is offline
evap emission
Ok so i keep getting this code p0446 EVAP emission control system vent circuit malf but my truck isn't running bad. Where should i look for this problem, vapor canister? i have no clue and don't have much money to take it in right now. 1996 gmc jimmy 4dr 4.3
Old 06-27-2007, 01:40 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: evap emission
I am pretty sure that I had the same code which is basically a bad gas cap. Go buy a new one for about $10 USD. Don't forget to reset the system.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 06-27-2007, 02:16 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: evap emission
Any other codes?
Check all hoses and vacuum lines on the system
First test is to clear code.
Remove gas cap and turn on key and read the fuel tank vacuum.
If it does not read 0 in h20 vacuum repair fuel tank vacuum sensor.
If it reads 0 in h20 with cap off it is going to take some more testing and test equipment to check it out.
Post back the reading.
MT
