Old 06-27-2007, 12:10 PM
new2mitsu new2mitsu is offline
Engine Swap
Ok, so i think this is the engine im gonna get, but can someone tell if this'll fit in my 93 VR4 w/ out modification, it says 90-99 but, i kno they changed the CAS in 92.5 so will it work???
http://japandomesticmotor.com/engine...hp?EngineID=43
Pls Lemme Kno, i need to get this damn thing swapped ...
Old 06-27-2007, 02:17 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: Engine Swap
http://www.stealth316.com/0-frames.htm
That link might help..
Old 06-27-2007, 07:44 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Engine Swap
w/o modification? HAHA! LMAO! if you own a 3000GT/Stealth, the word "modification" should be part of your daily vocabulary.
but as for that particular engine, i can see that it does have the 91-92 adjustable CAS on it. so it WILL fit in your 93 VR4, but you'll have to slightly modify some wires.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
